Hi, I've been repairing a Xone 62 mixer completely, the power supply was completely bad and I had to rebuild one from scratch, obviously I made a linear PSU design and already noticed audio quality improvements compared to the original one...
Sadly when repairing one of the channels, I noticed that when I enable the EQ, one of the channels goes pretty quiet (Right/Left) and I wasn't able to trace back the problem, I've been looking with my oscilloscope and my multimeter practically everywhere and still haven't found a reason of why the signal is low on that side, from what I can notice is that the input of the op-amplifier is low when the eq is enabled and so obviously it's output is going to be low.
Is there anyone who had experience repairing this kind of problem on the Xone 62 or has any idea of what I could check?
Attached you can find the documentation and the board I am talking about is the C3630 issue 2 (Input 3-6 Circuit), if any information or even a scope screenshot is needed, don't worry to ask.
PS. The op-amp is the IC3 (checking output 1)
Also this is my first post so if anything is wrong, let me know and I will try to correct myself for the next ones
