Wow, you're definitely taking it better than I thought! And to say that a more experienced person wouldn't have made the same mistake is quite an understatement. I mean, yeah, people can make mistakes, but I'd say this one goes more to common sense. High voltages can literally kill you, and you thought it'd be a good idea to poke around with a soldering iron on a live circuit? That's just incomprehensible to me. For future reference, the only thing you're allowed to do on a live circuit is to measure voltages with a multimeter (and that's if you know what you're doing, being careful, and using one with proper input protection) Anyhow, I'll admit that initially, I was shell shocked from reading what had happened (as you've risked your life doing something very unsafe, taking high voltage for granted) but I'm willing to go past that now (just be more careful in the future, because again, your life literally depend on it, and if you'd get electrocuted, things might not end well!). And for the record, electrolytic capacitors have a 20% tolerance up or down, so you should never replace a 1000uf with 470 (as that's way below) and even if you think it helped with diagnostics, it's just not right way to go. Also, LOW esr/impedance caps are generally used in these type of circuits (so using caps made for general purpose use isn't a good idea). Anyhow, 99.9% of these T12 controllers can accept 12-24V, so you could use a laptop ac adapter or a 12V adapter to test things further, and as long as you're just gonna use it to test the display (without operating the iron) current draw shouldn't be an issue. Provided the adapter has a DC jack, you could just desolder the red (positive) and black wires from the power board, shove the red one to the inside of the jack, and clip the black to the outside of it with an aligator clip (check the polarity symbol on the adapter itself first though!) most of em have the positive on the inside. Doing this would tell you if the issue is with the controller or the power board. Good luck
