Author Topic: KSGER T12 - Tip not grounded  (Read 1334 times)
Offline blalloTopic starter
« on: January 22, 2024, 11:19:43 pm »
Hello everyone,
i have a KSGER T12 without internal psu, it's powered via a 24v dc external PSU.
Today i noticed that while i was soldering a led, it turned on slightly, so i suppose the tip is not grounded.
Do you know how to solve this?
Thank you!
Offline thm_w
  • Non-expert
Re: KSGER T12 - Tip not grounded
« Reply #1 on: January 22, 2024, 11:38:09 pm »
Open it up, you should see a point on the secondary side you can solder a earth wire to.
https://www.eevblog.com/forum/dodgy-technology/dangerous-solder-station-ksger-t12/
« Reply #2 on: January 24, 2024, 07:21:16 pm »
Sadly that's not my case, i have a single board without the psu board, i power it via an external PSU (it's like a laptop psu with barrel plug)
That's my mobo:1990264-0
Offline BrokenYugo
« Reply #3 on: January 24, 2024, 08:07:04 pm »
See the big hole marked "PE" in the lower right corner? That's the earthing/grounding point, "Protective Earth".
Offline thm_w
  • Non-expert
« Reply #4 on: January 24, 2024, 10:51:59 pm »
That's my mobo: (Attachment Link)
Check if your laptop PSU is grounded/earthed, measure resistance from output barrel to earth ground. Some already are.
If it is not, you'll have to either get an earthed PSU, or wire up a ground lead yourself. Sometimes done by (carefully) hacking up an old power cable.
Online elektryk
« Reply #5 on: January 25, 2024, 08:28:54 am »
Some of such "power bricks" can be easily opened.
Offline S. Petrukhin
  • Country: ru
« Reply #6 on: January 26, 2024, 11:29:22 am »
I would not recommend hard-grounding the tip.
If you are going to solder only de-energized boards, it is quite acceptable, but sometimes you want to keep the power on during repairs.  :scared:
Do this through a 1M resistor - for a static charge, this will be enough to drain.
Modern LEDs can glow when the wind blows.  :)
And sorry for my English.
Offline floobydust
« Reply #7 on: January 26, 2024, 08:54:47 pm »
A 1MEG resistor is OK for ESD grounding - a wrist strap, a workbench etc. but not for a soldering iron, especially one that has a transformer wound by villagers.
One person tried it on their KSGER look at the scope traces tip went from 180Vp to 122Vp with the 1MEG added, not much help. This is with the KSGER PSU.
High quality laptop bricks, two-prong can have low leakage. Just measure ACV from tip to PE. I do see a 1MEG used in them though.
Best is a three-prong laptop brick.
The following users thanked this post: thm_w, S. Petrukhin
Online elektryk
« Reply #8 on: January 26, 2024, 09:13:50 pm »
My notebook PSU used in soldering station has 1M resistor with parallel capacitor between earth and output ground, other one layin' around has 0.1R measured with multimeter, so its definitely hardwired by the manufacturer.
I use the first one, AC multimeter shows about 0.4V and 0.04mA beetwen tip and earth connection but it is able to lightly glow red LED, which blinks with a similiar frequency as the heater.
  • Country: ru
« Reply #9 on: January 27, 2024, 02:09:42 pm »
Maybe the induced voltage has a high frequency and penetrates due to the parasitic inductance of the conductors?
I would try adding 10 nF to PE capacitor.
