Author Topic: Kyoritsu 1009 goes "OL" at each measurement  (Read 1173 times)
Offline +syncTopic starter
« on: February 16, 2021, 07:35:05 pm »
Didn't use my old Kyoritsu 1009 for a while.
So, I put new batteries in it and it seemed to work, at least all of V, Ω, ][, Hz, µA, mA and A displayed the normal output when leads are not connected.
And Ω, µA, mA and A seem OK when leads are connected.
However for some reason, V, Hz and ][ (capacitance) do not work:
 - for whatever V measurement,  AC or DC, like a 1.5V battery or from a power outlet, it shows after 1 second "OL", meaning Over Range.
 - same for ][ (tried from ~500 µF to ~2000 µF)
 - Hz simply remains at 0.000 and doesn't move at all
The last time I used it, all of that was working perfectly.
Can the affected features give a hint on where the problem might be?
More on the C/C++ development side, I'm afraid.
Offline coromonadalix
Re: Kyoritsu 1009 goes "OL" at each measurement
« Reply #1 on: February 16, 2021, 08:09:41 pm »
rotating dial ?   crust,  defective contact spring ?   fuses ?
« Reply #2 on: February 17, 2021, 07:50:43 am »
Bingo! Was the rotary switch, one of the contacts was misplaced.
Not sure why that triggers the OL behavior, but anyway, working now!
« Last Edit: February 17, 2021, 07:53:37 am by +sync »
« Reply #3 on: February 17, 2021, 11:47:36 am »
you have a dial contact broken it seems ?
« Reply #4 on: February 17, 2021, 02:05:04 pm »
Well, it's a picture taken from the Internet somewhere... as it's worth a thousand words, and I didn't know how to describe these things  ;D
