The La Crosse brand is one of many brands (eg. Technoline, etc) that have re-packaged this very popular AA/AAA batt. charger. (Probably made by common Chinese manuf).
Anyway, this BC is know for its flaky push buttons that go bad. Here's a video of someone repairing one:
https://youtu.be/Husb1Aaa5HAI have no idea about the full history of my unit except that it came from a house that was roach-invested. Prior to opening, the unit was apparently charging fine (??) but some of the LCD display was not showing upper half. (Later isolated to a dirty Zebra strip -- easy fix).
Upon opening the unit, there was a literal ecosystem of small roaches and spiders (all alive and scurrying). And many dead bodies of roaches (or were they molts??). I'm assuming they chose the interior for its warmth. I have seen roached infest modems, routers, etc.
Anyway, after air blasting the mess -- very dense -- and following it up with a 95% iso alch + gentle toothbrush and q-tip wiping (and it is v. difficult to remove the roach excrement) ... and following it up with MULTIPLE q-tip/alch and Deoxit treatments of the contacts, I still
can't get bank selector switches 2,3,4 and the MODE button to work. It is possible, that the
brand new unit was also defective--out of the box (
). The condition of the non-working buttons/switches (the PCB contacts, and the depressible aluminium momentary switch itself, are in the same condition as the working switches, if not better).
I did check all the elctro caps on the PCB and in the wall-wart ... all test fine.
The unit works / displays fine ... incl. most of the other buttons/functions.
The non-working switches are a mystery?
