i think its embedded in the executable, and maybe decompress in the computer memory
just to let you know, a new model is out XGecu T76 it does both 56 and 48 ...
normally you send requests to the makers and maybe they'll add a new chip ?
no afilliations
T76 Hardware Parameters
●Master:32-bit RISC-V MCU + FPGA (BGA256)
[TYEP C] USB3.0 SS 5GHZ Compatible USB2.0 480MHZ
●Exterior Dimension: 12x7x2.8cm
High-cost and high-density process, product size is greatly reduced.
● 48-pin full drive 10+ISP 28-way dedicated I0.
A total of 76-way external high-speed driver, high reliability
●VCC voltage 1.2-6.5V 64-level adjustable, the
VPP voltage 6.5-25V 64-level adjustable. Supports programming up to 25V
I0 communication signal voltage 1.2V-3.6V adjustable in 64 steps.
VCC 120MA-450MA overcurrent protection adjustable
VPP 150MA overcurrent protection
Power consumption: 5V <1A. Static power consumption: 150mA.
All chips do not need external power supply. For one to four mass production programming can be connected to an external power supply 5V-5.5V.
External power supply current n*1A or more, the programmer has multiple protection for external power supply.
Over-voltage protection / reverse connection protection / over-current protection / low voltage tips.
T76 chip support
●26 27 28 29 37 39 49 50 Series Parallel ROM, EPROM, EEPROM
●24 25 35 45 85 93 95 Serial series EEPROM.
●Support P-NAND FLASH: NAND New model chips can be added with customized parameters.
●Support SPI NAND, (SD NAND/SD Card)
●Support EMMC/EMCP
● Microcontroller series
●GAL/CPLD Programmable Logic Device Programming
● Support VGA tool and VGA ISP programming
●SRAM chip test
●Powerful 54/74F/LS/HC CMOS4000 series IC logic test.
