Electronics => Repair => Topic started by: big jooe on September 30, 2024, 09:34:33 am
Title: Lambda EMS 33-33-3 power supply
Post by: big jooe on September 30, 2024, 09:34:33 am
Hi all,
Have obtained Lambda EMS 33-33-3 power supply but it does not have voltahe setting helipot, only current setting helipot. How to adjust voltage on this supply? ...or someone has a schematic of it?
many thanks
Joe
Title: Re: Lambda EMS 33-33-3 power supply
Post by: artag on September 30, 2024, 11:16:45 am
It seems to be covered by the manual at https://www.artisantg.com/info/TDK_Lambda_EMS_33_33_3_TP_LB_CE_1568_Manual_201981311314.pdf (https://www.artisantg.com/info/TDK_Lambda_EMS_33_33_3_TP_LB_CE_1568_Manual_201981311314.pdf) but presumably in a version that has no or few front panel controls. However section 3.3.2 describes how to program it using the rear panel tag strip which might be appropriate.
