If noisy pots are troubling you, have you heard how the BBC cured the problem in the 1950s? It is still one of the most inventive bits of EE I have ever heard of and they got called "Light Pots".
Basically they used germanium transistors as opto-amplifiers and used normal pots just to control the intensity of light shining on them. The bulbs were under-run so they lasted a great length of time, and the set-ups were shielded against stray light, just a little being allowed to leak out to give a visual indication that all was well inside.
Another nice little bit of lateral thinking involving light was a friend of mine many years ago. He wanted my last 8m of fiber optic cable from me. Knowing he wasn't really into that sort of thing and this cable being very old and thick so was not rated for modern comms, I had to ask what he was after it for? Turns out he had just got his car licence and had already got stopped for a tail light not working. So instead of designing some complex sensor, he was just drilling a small hole and poking the end of the FOC inside. The other end he was running to the dashboard. Maybe not a perfect solution, but quick, cheap and not a lot to go wrong really compared to home brew sensors.
