Hello!
I have a Laney CUB 10 valve amp that's barely audible.
When I crank the gain and volume it's just loud enough to be heard over the guitar itself.
There is no hum or other sounds so everything is quiet, not just the guitar.
The guitar sound coming from the amp is quite clean, not much distortion going on.
Not sure if this aids in the troubleshooting but the power led is not lighting up.
What I have tried/checked:
Tried the guitar and cable in another amp. Nothing wrong there.
Replaced all the tubes and got the same symptoms.
Checked the output transformer for shorts or any other issues, none could be found.
Checked the voltages of the power transformer, got 504 V, 45 V and 7 V.
Visual inspection of the circuit boards.
Measured the "larger format" diodes and resistors while in circuit.
Schematics can be found here:
https://www.thetubestore.com/lib/thetubestore/schematics/Laney/Laney-Cub-10%20(2009)-Schematic.pdfNew to electronics and don't really know where to go from here.
Any input would be greatly appreciated!
Best regards
