Hi all (&Dave) been watching the eevblog videos for 4 odd years now, and finally thought i would post a question.. So just joined!
Ive just been given a faulty EX1810R
Doesn't power up, you get the familiar tick-tick of a switch mode trying to start. TTI supplies are good supplies so worth fixing. The primary side seems ok, and the mains input fuse hasn't blown. With the exception of the incoming mains reservoir cap which is fine, there are only about 7 other electrolytics, so i've ordered some low ESR replacements and we can give that a whirl first by changing them. I did check a couple out of circuit and my ESR meter shows them to be leaky... but its always hit and miss. All the main rectifier diodes seem ok and are not short or open....a quick poke at a few key resistors didn't show up much either
.. any thoughts from the forum?
Has anyone got a service manual or diagram too?
Thanks in advance all
Neil
