Author Topic: laptop Lcd help needed Hpfolio 1029  (Read 480 times)
Offline dave_j_fanTopic starter
  • Country: in
« on: June 24, 2022, 08:48:09 am »
Are thse lcd compatible
hp folio 13 and hp probook 5310
because i am getting  5310lcd
i am in india
so we cant buy via ebay.com because shipping is high.
Online wraper
  • Country: lv
Re: laptop Lcd help needed Hpfolio 1029
« Reply #1 on: June 24, 2022, 09:10:52 am »
You should buy by LCD panel model, not laptop model. Not to say the laptop base model may come in variants with a different LCD which are not compatible. Websites like Panelook list specifications of the vast majority of panels, so you can compare if important specs match if you buy a different LCD model as replacement.
  • Country: in
« Reply #2 on: June 24, 2022, 04:19:24 pm »
thank u
lcd is F2133wh4
can anyone helpme with few other compatible lcd numbers
Online wraper
  • Country: lv
« Reply #3 on: June 24, 2022, 06:25:19 pm »
LP133WH4-TJA1 should do the job, apparently it's the only compatible type. This is a very specific LCD and there are no tons of replacements as usually.
« Last Edit: June 24, 2022, 06:28:28 pm by wraper »
