I apologize for my mistake... One more question... You search with order all the codes that shown on the site until you will find a voltage reference component or you use another method. Many thanks for your help.
Quote from: 2X on August 21, 2023, 10:11:51 amI apologize for my mistake... One more question... You search with order all the codes that shown on the site until you will find a voltage reference component or you use another method. Many thanks for your help.You can mentally filter the search results by package type. In this case I was looking for SOT-89 or similar. Next I look for circuit context (which you provided) to narrow down the candidates.Finally, I try to find a photo of the part:https://www.google.com/search?q=KIA431AF&tbs=isz%3Am%2Citp%3Aphoto&tbm=ischhttps://www.aliexpress.com/wholesale?catId=400103&initiative_id=&SearchText=KIA431AF
According to the connections I believe you are totally right that the "Marking Code 3B 514" is a voltage reference.
Of all the possible 3B SOT-89 I've found, KIA431AF is a good guess, given that it goes to a reference voltage input and how it's connected makes sense for a 2.5V reference.
