I totally missed that second link
Anyways, looking at that, that one looks like the one off the asus.
The ground shield solder tab by the thru hole contacts
Is even with both rows of contacts, the one in that second link shows the back row out of alignment.
I may be able to hack it up a bit to fit. I mean the pinout is standard, it just seems to be the placement of the pins to the ground tabs.
Maybe ill cut the tabs off and just solder them in the board and then to the shield.
