Thank you, that's very helpful! I've never done this kind of work on a motherboard before - I've replaced leaky electrolytics, and I SATA modded my Thinkpad T43p, but this is pretty extreme for me. Which is another reason why I'm so keen despite the unremarkable machine it's for. I'm learning here!
Why some are solder covered and others are gold plated, is anyone's guess.
Could it be that the tinned ones are test points for board continuity and trace resistance/capacitance used during board assembly, and the gold plated ones are for testing populated boards? That would explain why they are tinned; they would have served their purpose at soldering, and their somewhat peculiar locations. I confess I know
nothing about the manufacture of multi-layered boards, except that they have multiple layers - sometimes connected with "vias"
I didn't even know it was possible to create "blind" vias - an interesting engineering problem! I'm guessing such vias would be inserted when only some board layers have been added?
Then its just a case of guessing the value of the caps, replacing the components, patching the tracks, and hoping there isn't any unseen electrical damage.
I've already identified the two components in area "A": a dual schottky diode and a 100k 0402 resistor. The capacitors in area "B" I'm going to desolder, and see if I can measure the two that still have somewhat intact terminals (by tacking some Kynar wire onto what's left). If not, I'm going to go with the suggested 100nf & 1uF.
Edit: I don't know what type of solder they've used but I had to set hot air temperature to 500°C to get it to melt! Seemed unusually stubborn, even for a lead free composition.
