Author Topic: LASER DIODE ID  (Read 679 times)
Offline tekguyTopic starter
LASER DIODE ID
« on: September 29, 2022, 02:00:05 am »
tHIS DIODE IS DEAD,ITS FROM A CD PLAYER,CAN ANYONE ID IT PLEASE SO I CAN GET A REPLACEMENT?,THANKS IN ADVANCE.
Re: LASER DIODE ID
« Reply #1 on: September 29, 2022, 02:01:18 am »
Sorry didnt mean to shout,caps lock key was toggled!.
Offline Haenk
Re: LASER DIODE ID
« Reply #2 on: September 29, 2022, 07:32:39 am »
These lasers are all special parts and were not publically available. There is zero chance of finding one, unless it's a spare part (for service) or pulled (removed from another machine).
So essentially your only option is to pull one out of a working machine (which might be otherwise damaged or in bad shape - unfortunately, the diodes were the most common part to fail...)
Re: LASER DIODE ID
« Reply #3 on: September 29, 2022, 07:43:50 am »
Bummer,i thought that was the case,its a candidate for landfill then i guess!.
Offline Haenk
Re: LASER DIODE ID
« Reply #4 on: September 29, 2022, 10:28:50 am »
Sidenote: it does look extremely corroded - since the pickup mechanics itself is quite fragile, I honestly doubt that a new laser would be of much help anyway - plus it would need adjustment
