I started using my old (4:3 ratio)Fujitsu Siemens lcd as my secondary monitor. it runs perfecly, but the hissing sound drives me crazy. The monitor is pretty old so i dont know if some of the caps are damaged or they dried out (it might me
) or the sound is making the CCFL tube. The sound starts right after i turn the lcd on, even before the image comes on, but i guess the CCFL tubes must be already on. I read that the tubes start making noise when they are set on low brightness (bcs PWM) but after i turn the brightness down, it starts making different noise(without effect on the first one)
Do you know whats causing the sound? or is it just common problem with older models?
Thanks very much,
kralik
