Author Topic: LCD module backlight identification  (Read 1056 times)
Offline khaahkTopic starter
« on: March 24, 2022, 01:14:12 pm »
What type of backlight is this? Where to buy replacement?
Offline TheMG
Re: LCD module backlight identification
« Reply #1 on: March 24, 2022, 01:19:00 pm »
Electroluminescent (EL).
Pretty much obsolete nowadays due to LED backlights.
Keep in mind these EL backlights run from high voltage AC, so a LED retrofit would require removal/bypassing of the high voltage EL driver circuit.
The following users thanked this post: khaahk
« Reply #2 on: March 24, 2022, 01:37:50 pm »
Thanks for the information!
Online Audiorepair
« Reply #3 on: March 24, 2022, 01:38:30 pm »
There are companies throughout the world that still make these things.
You don't reveal where you live.
https://www.backlight4you.com/EL-Panels/EL-Replacements:::46_130.html?language=en
Offline George Edmonds
« Reply #4 on: March 24, 2022, 02:59:15 pm »
Hi
These are not high voltage devices and they have a known life time mesured in hours
Look on eBay thre are listings for the supply of them
G Edmonds
« Reply #5 on: March 24, 2022, 09:11:52 pm »
Seems like a good source, thank you! (EU is fine)
Hi
G Edmonds
By "these are not high voltage devices" you are referring to the  EL-Replacements website linked above or i did not understand you correctly?
They seem to me like a direct replacement.
Thanks
Online Audiorepair
« Reply #6 on: March 24, 2022, 09:21:40 pm »
[/quote]
Thanks
[/quote]
There are similar looking LED backlights from the same company.
https://www.backlight4you.com/LED-Backlights/LED-Retro-Backlights:::135_137.html
