second video only shows that its possible to remove glue and directly solder flex to pcb
Today - Fixed a 5.00 Multimeter (Ebay) - NEW 7 FUNCTION DIGITAL MULTIMETER DC AC MULTI-TESTER VOLTMETER OHM - loose test lead connections. To test current, I can add a 3rd removable test lead if ever needed. Right now testing Capacitance, Voltage , Ohms, and Continuity. Cut off test leads and soldered wires directly to circuit board of the MM - Works Great!!
Testing Capacitance with Cheap 5.00 Multimeter -
Don't have a hot air gun. Plan: unglue strips by heating the strip tape carefully / quickly with a soldering iron adding Fast Chip SMD Removal Alloy to the tape. The SMD Fast Chip Alloy lowers the boiling point of solder / it might lower the melting point of the glue. Clean residue with isopropyl alcohol. Then solder strips in. Need to also check for bad caps on the digital panel by the TCon board.
I ordered -
- Fast Chip Kit for Quik SMD Removal with a Low Temperature Alloy - SMD Removal Alloy - Ebay
- Liquid Flux - CIRCUITWORKS CW3220 NO CLEAN SOLDERING LIQUID FLUX LEAD FREE - Ebay
- (X2) SMT SMD Component Welding Practice PCB Board Soldering Plate DIY Suite Kit - Ebay - Practice - Practice - Practice!!!!
- Fluke TL75 Hard Point Test Lead Set for Multimeter for FLUKE - Ebay
- Fluke 101 Basic Digital Multimeter Pocket Portable Meter Equipment Industrial (Amazon Good Price)
Alot of this gear I will have for many future repairs. Looking at this as an investment. And I was going to throw away the LCD Panel the other day!! Gut tells me if I can get this repair to work, it will last a long time. Plus, I'm learning alot which I really needed to do and appreciate. Must keep costs down.
