Author Topic: SOT23-6 with marking code LC01 or 7300  (Read 412 times)
Offline spetrosTopic starter
  • Country: gr
« on: August 18, 2024, 07:35:51 am »
Hello.
I have tried to identify the following IC.
As i can see from the other components near to it  this is a bulk dc converter controller but i cannot find which one.
Thank you for any help
« Last Edit: August 18, 2024, 07:39:43 am by spetros »
Offline Vicus
Re: SOT23-6 with marking code LC01 or 7300
« Reply #1 on: August 18, 2024, 11:37:05 am »
Can you identify the pin function?
Are you shure is not a linear device? Where is the coil?
  • Country: gr
« Reply #2 on: August 18, 2024, 11:55:21 am »
Thank you for your answer.
I am attaching another one photo of the board with some components removed.
I am sure because it takes 12V and at the outputs 5V
Online fzabkar
« Reply #3 on: August 18, 2024, 02:47:52 pm »
The topology looks more like a boost converter with an output voltage of 12V. Pin #3 looks like the feedback pin, with the FB voltage being 1.0V.
  Vout = 1.0V x (100K + 9100) / 9100 = 11.99V
« Last Edit: August 18, 2024, 04:42:42 pm by fzabkar »
The following users thanked this post: spetros
  • Country: gr
« Reply #4 on: August 18, 2024, 04:10:31 pm »
I attach the circuit diagram of the unknown ic .
Maybe it will help to identify it.
Edit ( The diode is not shottky but a diode with marking L2V9 which is unknown too )
Also i have found the same IC but with marking AJ2hD from another same board
« Last Edit: August 18, 2024, 04:45:33 pm by spetros »
Offline Vicus
Online fzabkar
« Reply #7 on: August 18, 2024, 04:56:09 pm »
AP5100WG / AP5100W, Diodes Inc, step-down converter, 1.2A, 1.4MHz, VIN 4.75V to 24V, marking AJxxx, SOT26
https://www.diodes.com/assets/Datasheets/AP5100.pdf
MP2359 looks compatible:
https://www.monolithicpower.com/en/documentview/productdocument/index/version/2/document_type/Datasheet/lang/en/sku/MP2359/document_id/228?srsltid=AfmBOopTtu2j1NZVhDFMtHLM87ERnWK7vWUJrdpoFSksD4QmzoLYddZ_
Also AMS1073 ...
http://www.datasheet.hk/download.php?id=1975839&pdfid=9218D18D47689B304860A1D6AEF396E8&file=0489\ams1073_7244640.pdf
The diode could be MBR120VLSFT1 or NRVB120VLSFT1G (Schottky Power Rectifier, Surface Mount, 1.0 A, 20 V).
http://markingcodes.com/search/c/L2v
« Last Edit: August 18, 2024, 07:23:59 pm by fzabkar »
  • Country: gr
« Reply #8 on: August 19, 2024, 03:00:24 am »
THANK YOU fzabkar for your  detail information
You were very helpfull :-+
« Last Edit: August 19, 2024, 03:02:03 am by spetros »
