Author Topic: LCD monitor motion traing ghosting problem.  (Read 254 times)
Offline sdancer75
  • Country: gr
« on: September 14, 2019, 11:14:53 am »
The motion trail ghosting problem, is a monitor or video card problem?
If its a monitor problem what kind of part is responsible for this?
Regards,
« Last Edit: September 14, 2019, 11:16:24 am by sdancer75 »
Offline shakalnokturn
Re: LCD monitor motion traing ghosting problem.
« Reply #1 on: September 14, 2019, 01:04:29 pm »
Not sure in your specific case, usually this is the sort of symptom you'll see with a bad shielding.
The following users thanked this post: sdancer75
Offline Dacke
« Reply #2 on: September 14, 2019, 03:03:50 pm »
Agreeing with the shielding issue shak said.   Try moving the monitor/cable around and see if anything changes.  If you're using VGA,  try replacing the cable.
Offline Rasz
    • My random blog.
« Reply #3 on: September 14, 2019, 03:57:52 pm »
vga cable?
Offline sdancer75
  • Country: gr
« Reply #4 on: September 14, 2019, 04:46:41 pm »
This is a computer in my work..... So, as soon as I return to work, I will test the cable I will let you know.
Best Regards,
