Author Topic: LCD Monitor troubleshooting  (Read 20120 times)
Online wraper
  • Country: lv
Re: LCD Monitor troubleshooting
« Reply #25 on: November 02, 2014, 08:28:05 pm »
Well, I think a bit late but worth watching.
Offline TorArneTopic starter
« Reply #26 on: November 02, 2014, 08:40:36 pm »
Its dead, docs says max 600v.
Did you probe secondary of the CCFL transformer  :scared:? Well, I warned  :phew:. Or considering blown fuse, did you probe something connected to the mains? Well, I asked for primary winding, guess you probed wrong primary as I meant inverter?
I asked for different board photo. Small PCB that sticks out of the PSU PCB near CCFL inverter transformer.
I probably did something wrong yeah ;)
Its no problem, was a really cheap scope. (think it was 45usd)
Tried fixing it.. but there's something really wrong with it.. so going in the trash.. hehe..
Here's the correct board, probably. :)
Offline bithead9
« Reply #27 on: November 02, 2014, 08:49:25 pm »
FYI Great resourse for LCD monitor repair:    http://www.badcaps.net/forum/
Good luck on your repair! :)
Online wraper
  • Country: lv
« Reply #28 on: November 02, 2014, 10:45:24 pm »
Here is schematic of this PCB. You should check highlighted signals. Measure voltage on C6 and C2. Post brightness min/max, switched off voltages. Don't know which particular brightness control input is used in this case. PWM is ON/OFF input + brightness (optional). Brightness can be controlled by PWM or PID which is analog brightness control input. If PWM is used, PID should always stay at +5V, otherwise voltage must change on it depending on brightness.
« Last Edit: November 02, 2014, 11:14:42 pm by wraper »
Online Alex Eisenhut
  • Place text here.
« Reply #29 on: November 02, 2014, 11:52:14 pm »
Yikes, don't probe the secondary with a regular scope probe! The voltage ratings are just for DC. Even with a 1000X probe I got into trouble, there's some serious power there at a high enough frequency to derate the probe to a much lower voltage!
Online Shock
« Reply #30 on: November 03, 2014, 04:44:49 pm »
Here is a better picture of the boards. Having nice clear photos helps.
I take it that you have done the basic stuff like try different inputs to the monitor, test it on a bios screen and reset the defaults to confirm they are indeed suffering the exact same problem?
Since you have multiple of the same model can't you swap testing the CCFL cable connected from another screen? Will not work if they are in series though.
I'd be checking the ballast caps and the HV transformer as well.
Do you have a working one?
« Reply #31 on: November 08, 2014, 10:10:43 pm »
DIM 3,26v
PID 1,29v
Need to connect a monitor to be able to adjust brightness. will try and do that now
Tor Arne
« Reply #32 on: November 08, 2014, 10:13:30 pm »
I do have a working one at work.
The rest i have are all broken with the same fault.
I have tested reset to default and all kind of stuff.
Nothing helps.
Even the menu (without anything connected) is dim.
I have testet ALOT of caps, not found a single bad one yet.
Tor Arne
Offline TheBay
  • Country: wales
« Reply #33 on: November 08, 2014, 10:22:49 pm »
What panel is in this, Make and Model?, could be driver chips on panel or mainboard is weak, I don't think its inverter/ccfl issue.
What voltages are present on mainboard from PSU?
« Last Edit: November 08, 2014, 10:24:43 pm by TheBay »
« Reply #34 on: November 08, 2014, 10:26:26 pm »
What panel is in this, Make and Model?, could be chips on panel or mainboard is weak, I don't think its inverter/ccfl issue.
Here's a picture of it
Offline TheBay
  • Country: wales
« Reply #35 on: November 08, 2014, 10:29:03 pm »
I had a feeling it would be an LG Display Panel for some reason!, the boards look like LG too but no markings, awful PSU/Inverter design. Did they really cheap out on parts lol.
Can you describe the flickering, is it on the screen? or if you look behind at backlight is it that flickering?, is backlight bright when looking at the side of it? I have a feeling its Panel or scaler board.
Do you have a hot air station and/or ESR meter?
« Last Edit: November 08, 2014, 10:46:55 pm by TheBay »
« Reply #36 on: November 08, 2014, 10:46:23 pm »
I dont recall seeing the flickering on other monitors i got.
Backlight dont seem to be flickering.
Offline TheBay
  • Country: wales
« Reply #37 on: November 08, 2014, 10:48:06 pm »
Have you got a hot air station and an ESR meter?
The main IC on mainboard on these type of scalers sometimes get poor joints, caps are also weak.
Check all voltages going in to mainboard too.
« Reply #38 on: November 09, 2014, 12:06:31 am »
Sorry, i do not have any of that.
I do have a hot air gun thou.
Tor Arne
Offline TheBay
  • Country: wales
« Reply #39 on: November 09, 2014, 12:11:19 am »
Do you have the right nozzles? Might be worth heating up the legs on the main scaler ic, also check pcb smd fuses etc.
Online wraper
  • Country: lv
« Reply #40 on: November 09, 2014, 08:56:27 am »
DIM 3,26v
PID 1,29v
Tor Arne
Then PID voltage must increase with increasing brightness. If it does not, try to solder a ~1k resistor in parallel to R13 and see if brightness becomes normal.
Offline Vito_R
  • Electronics Technician
« Reply #41 on: November 09, 2014, 10:06:50 pm »
BTW just noticed that you changed some capacitors. If you fix this monitor, throw those green Chengx junk away and solder original ones (suppose they were Rubycon) if you still have them, or get something better. Those Chengx are not only poorest quality capacitors but also have huge ESR. I once bought few, didn't check the brand they gave me at the local shop because they usually had Jamicon WL in stock which are green too. So when I measured, they had ESR like 2-3X bigger than general purpose capacitors with the same capacitance and voltage specifications. Moreover, they even don't write series on them, just LOW ESR which they obviously are not. There seems to be series marked on yours, but they are too tiny to be good compared to original ones anyway.
Agree get rid of those crappy Chengx caps.  Replace all electrolytics with high quality low ESR Japanese caps and you'll extend the life of your board for many years.  I like using Nichicon PW, HE, or HW series.
Do the job right the first time.  Quality over quantity will save you in the long run.
Online wraper
  • Country: lv
« Reply #42 on: November 10, 2014, 02:44:33 pm »
Why should he replace all capacitors if they are all Japanese except one? It unliekely to provide much longer life as CCFL or backlight transformer should die first IMO. Even if some capacitor dies, it will be only one, not bunch of them altogether.
Offline Vito_R
« Reply #43 on: November 10, 2014, 05:50:45 pm »
I meant only the chinese caps, not the ones he has already replaced with Japanese.  Those chinese caps eventually will fail one at a time if you just replace the defective ones.  Better to recap all at the same time then have to open up the monitor again when the next failure occurs.
« Last Edit: November 10, 2014, 05:53:11 pm by Vito_R »
Online wraper
  • Country: lv
« Reply #44 on: November 10, 2014, 05:53:17 pm »
Well he have wrote previously that he will put original Rubycons back. Chengx were those he replaced. Actually I haven't ever seen that crap to be present in any monitor from factory.
« Last Edit: November 10, 2014, 05:55:57 pm by wraper »
Offline Vito_R
« Reply #45 on: November 10, 2014, 05:54:35 pm »
I guess I missed that, sorry.
Offline kimi007
« Reply #46 on: June 26, 2015, 04:28:28 pm »
Hello J have the same problem.
Rotate cables to lamps, but you must to extend it.
That will solve problem.
Sorry for my bad english.
Best regards.
Miki
Offline luke9511
« Reply #47 on: October 17, 2015, 03:49:57 am »
hello and good day all, i came across this thread while searching for a way to fix the same model of monitor as the op, i have about 4-6 of them all with the same issue there is a very faint picture, it is either very very dark or very dim and some flickering, does anyone have any ideas i can try?
