Author Topic: LCD Repair  (Read 2055 times)
Offline dimitris1989Topic starter
LCD Repair
« on: December 24, 2014, 08:42:19 am »
Hello all,
I have a Samsung T200 LCD monitor, and some time ago it started showing a white screen. At first it would recover after a few power offs and ons but now it's always white.
I opened it up, checked for bad capacitors on the power board but everything is fine. Is there anything else I can check or it's beyond repair?
Thank you
Online wraper
  • Country: lv
Re: LCD Repair
« Reply #1 on: December 24, 2014, 12:26:44 pm »
Try to reseat LCD cable connectors, move the cable, press with finger BGA chips and power on while holding.
Re: LCD Repair
« Reply #2 on: December 24, 2014, 03:19:42 pm »
Thank you for your reply
I tried it, but it didn't work
Offline AKM
  • Country: ba
Re: LCD Repair
« Reply #3 on: December 24, 2014, 05:53:57 pm »
TN panels usually work in normally white mode (it forms the picture by blocking unwanted colors from the backlight), so when you have a white screen on a monitor with TN panel, it is the panel which doesn`t work. Try checking the T-Con board for the voltages it needs to work(usually 5V); if there is a SMD fuse on the T-Con board, check it too; if the fuse is blown, check for shorted components before replacing it with an equivalent fuse(take care to notice components in parallel, especially the bypass capacitors).
