Author Topic: LCD repair  (Read 2321 times)
Offline adohertyTopic starter
LCD repair
« on: October 30, 2013, 03:38:50 pm »
I have a Samsung Syncmaster 204B that was failing. Did youtube/ebay searches, and by the plethora of  video results and parts kits, it is obviously a very common problem. Bought the caps (from Mouser Electronics,) put them in last night, now the monitor starts right up like it should, but now I have a new problem |O, I have about 10 vertical lines on the screen (green, blue, pink, red.) Did I damage something else while doing this repair, is it another part damaged on the power supply board (shorted/overheated?) Or did I somehow damage the LCD screen itself and now it is hosed?
Offline rexxar
    • Forever Tinkering
Re: LCD repair
« Reply #1 on: October 30, 2013, 04:33:08 pm »
If all the bars are together in a space less than a few inches wide, I'd suspect one of the column drivers. Check that all the flex connectors to the panel are seated correctly, then reseat them anyway.
Re: LCD repair
« Reply #2 on: October 30, 2013, 06:00:01 pm »
Thanks, I will try that and post results.
