Author Topic: tti tg315 service manual?  (Read 1706 times)
Offline vixoTopic starter
« on: November 06, 2017, 06:00:03 pm »
I picked up a cheap, new TTI TG315 on ebay. Unfortunately the DC offset isn't calibrated properly which is annoying.. looking inside there are a fair few trim pots but nothing on the pcb is labelled. Does anyone have a service manual or could give me any tips on finding one? I don't want to start twiddling pots randomly...
Offline glarsson
Re: tti tg315 service manual?
« Reply #1 on: November 06, 2017, 06:16:15 pm »
Have you tried the obvious option; ask TTI? They are usually very nice and will send what they have available.
« Reply #2 on: November 06, 2017, 06:32:54 pm »
I have sent them a message at aimtti.us. No reply yet - thought i'd ask on here in the meantime
« Reply #3 on: November 06, 2017, 06:53:47 pm »
Compare with the TG200 series manual. I think they have the same or very similar boards in them. Just a different case and counter arrangement. The design has been around forever.
DC cal on these usually calls for a DMM 4.5 digit or better, connect it across two pins in the DC summing amp and adjust the trimmer until there is a null reading. If you can find the summing amp and pot you can do this without the service manual. Basically you’re trimming the offset of the op amp.
« Reply #4 on: November 06, 2017, 07:08:57 pm »
thanks! good shout on the TG200 series manual. I'll have a look and a rummage..
