Going back to my days of DELL warranty repair work, laptop LCD panels were not necessarily the same and had different inverter boards with different part numbers. Just because they look the same, they may not necessarily be the same, unless you see both sides of the board and can verify each and every component, including passives, preferably with test equipment. Even then, they may not be with inner board layers doing different things. Personally, I wouldn't chance trying it, you could possibly damage the panel. If the sellers say you must match, then you probably should match. They are covering themselves from someone performing a repair willy nilly, not knowing what they are doing and then blaming the seller for their mistakes. Looking up the brand, it seems to be a low end TV and may not be worth the effort or money to fix.
