Author Topic: Repair of Plextor SSD PCB  (Read 17900 times)
Offline RGB255_0_0
Re: Repair of Plextor SSD PCB
« Reply #25 on: April 03, 2016, 03:15:47 pm »
Brilliant job.
Your toaster just set fire to an African child over TCP.
Offline jitter
« Reply #26 on: April 03, 2016, 08:16:15 pm »
:clap:
Sorted, soldered a test lead into the removed inductor and powered at 1.2 V. The current drawn is 0.6 A. Connected this supply first and then the SATA connector and power. Drive took around 10-20 seconds and then bingo, detected in my windows PC.
I was able to recover all of my critical data. My main objective is now complete. I may still try and repair the drive fully as a hobby, but will not really ever use it for anything important or critical.
Thanks all for your assistance! I would be nowhere close to retrieving my data without you!
 :clap:
Good to know it worked and you're welcome.
Given the power consumption of less than 1 W, I'd say that in this case, it was only the regulator that had failed.
I just noticed the datecode 1425 on the pcb and wondered if the warranty has expired...
Offline ruffy91
« Reply #27 on: April 03, 2016, 08:27:47 pm »
Probably not. But they wouldn't have repaired the SSD but just replaced --> bye bye data.
Gesendet von meinem JAZZ mit Tapatalk
Offline nidlaX
« Reply #28 on: April 03, 2016, 10:28:19 pm »
Nice job walking through this repair. It will be informative for anyone who faces a similar issue in the future. 8)
Online wraper
  • Country: lv
« Reply #29 on: April 03, 2016, 11:04:58 pm »
I guess you will have a hard time to find what IC it was. However you can try to find some pin compatible DC/DC converter IC (with synchronous rectifier) in DFN-6 package. Feedback resistors might need adjustment for proper output voltage, but repair is completely doable.
Offline jitter
« Reply #30 on: April 04, 2016, 05:46:35 am »
You may be right, but the point was now that the data has been retrieved, there's no need repairing it yourself if it's still covered by warranty (unless of course the famous "warranty void" sticker has been broken).
