The Toshiba 32C110U1 TV I'm using as my desktop monitor has started doing something really weird - or at least, I've never heard of it, but this is far from my area of expertise.
The screen freezes, and then fades to black starting on in the lower right of the screen, and fading to the upper left. The power switch also freezes, so that I can not cycle the power without unplugging the monitor. Sometimes, I unplug and plug it back in, and things will be fine for hours, other times it immediately does the same thing again. It seems to get more frequent with time.
Flickr link to a video.(Sorry about the video quality - all I had was my phone, and it is unpredictable enough it was pretty hard to catch. It does show the problem quite accurately.)
I've checked the ESR of all the power supply caps, but they are fine. I'm assuming this has nothing to do with the back light, because when I am behind the monitor to unplug it I can still see the back light through the vent holes. There is nothing which is visibly damaged - the cables all appear to be in good shape, and the larger ones I can easily check don't show any shorts or opens; and none of the chips have any black marks or other evidence of having been particularly hot. I've had it open three or four times, and when I do, pretty much all I can do is reseat all the connections. I did, last time, replace a piece of tape that was holding down the cable from the main processor board to the LCD controller, as the old one had lost all adhesion. This fixes the problem for a week or two, but then it comes back. I use this screen a LOT, mostly for CAD/CAM work, but also for hobby schematic and PCB layout stuff, so it is VERY frustrating, but buying a new monitor is not really in the cards (as in, credit cards) at the moment.
Any suggestions would be MUCH appreciated.
Gabriel
