Author Topic: LCR-TC2 multimeter  (Read 3070 times)
Offline kukulamaTopic starter
  • Country: cz
LCR-TC2 multimeter
« on: September 06, 2021, 02:40:17 pm »
Hello, I have recently bought a this great multimeter, it is almost identical to the one described here: https://www.eevblog.com/forum/testgear/tc1-lcr-meter-transistor-tester-fix/
It is really useful and helpful, but has one extremely annoying property, when I measure some component it shuts down after up to 25 seconds, I would like to disable this function entirely, the controlling chip of the function is shown in the post I shared, alongside with schematic of entire board, it is this one STC15L104W.
If necessary I am willing to desolder the chip and replace it with external switches.
Thank you very much.
Offline bob91343
Re: LCR-TC2 multimeter
« Reply #1 on: September 07, 2021, 12:06:18 am »
I think that's in the firmware so first you have to figure out how to program it, and then modify the code.
Online coromonadalix
« Reply #2 on: September 07, 2021, 02:44:48 am »
Well  you have to get an stc  isp programmer,  the software who goes with it  and hope you can read it  if its not read protected
or you have to do some bus sniffing if you see some data going out to the main mcu  or simply an pull up or down  ???  ......
for a simple shut down / watch dog  you may go a long route ???
https://www.stcisp.com/STC-ISP_update_history.html
