Author Topic: Seeking replacement rubber compresion seals for cable gland  (Read 716 times)
Offline LomaxTopic starter
  • Country: eu
  • Minimalist
« on: August 20, 2023, 09:11:50 am »
Ok, I give up. What are these things called?
I've spend a good while searching, Mouser, Digikey and eBay, but cannot find replacement seals for these cable glands - surely this is a thing? After all they are perishable, as evidenced by the photo, while the rest of the gland remains perfectly usable...
Offline jpanhalt
Re: Seeking replacement rubber compresion seals for cable gland
« Reply #1 on: August 20, 2023, 09:45:08 am »
When faced with situations like that, I resort to a local hardware store, auto parts suppliers, and/or small engine shops.  Faucet washers, other rubber washers and rubber/silicone tubing (e.g, fuel line, vent lines, etc.) will often substitute.  Even stacked O-rings might help.  If you need to cut rubber, use a sharp blade and lubricate it with soapy water.  PVC tubing cutters als work well with larger tubing.
If price is not an issue, McMaster Carr has a lot of rubber parts.
John
The following users thanked this post: Lomax
Offline Swake
« Reply #2 on: August 20, 2023, 08:36:13 pm »
Cable glands are still sold and in use. Exist in different metals and plastic. Any DIY shop should have some. Recover the rubber joint from a new one and put it in yours. That little metal washer is key to being able to turn the washer as it kinda slips.
When it fits stop using the hammer
Offline CatalinaWOW
« Reply #3 on: August 20, 2023, 10:36:56 pm »
This is one of those things that is never intended to be repaired, just replaced.  So just like ball bearings when the shield or ball retainer fails you just replace the whole thing.  If you are doing a museum quality restoration and want to retain the exact original appearance your best bets will be to do as Swake says and recover something usable from a similar new gland seal, or fabricate your own replacements from rubber or neoprene.  A laser cutter should make neat work of the job, perhaps you have a mate who owns one, or can talk a nearby advertising shop to do it.
Offline coppercone2
« Reply #4 on: August 21, 2023, 08:36:31 am »
you can maybe cast it from silicone rubber epoxy
Offline Roehrenonkel
« Reply #5 on: August 21, 2023, 09:02:12 am »
Hi Lomax,
have you tried to search for "M20" or "PG13.5" and  "Pflitsch" on digikey/mouser?
Tons of glands and sealing-rings.
Good luck
