The 2N5109 does not look ideal, but there is an acceptable chance it will work .
The main difference I see is slightly lower maximum voltage (you can analyze the circuit to see if this is going to be an issue), and lower gain (which may be a problem).
I would give it a try and see if the scope works and can be calibrated.
