G1 looks is too +ve, it should be around -2,000V, certainly more -ve than cathode K TP6 to bias the CRT dim/off.
I would check the extra HV multiplier stage for that. D16, D17, D18 (you already tested OK) they are LV diodes on a HV rail. C40, C41 not as likely to fail. C42 maybe.
Or something is loading that down.
The blanking circuit here is a bit hairy. Hitachi V212/V211 also uses the Toshiba 150BTB31 CRT, and very similar circuit. That schematic is drawn better with some waveforms.
Basically a HV multiplier making -1,900VDC to the cathode, and I think extra multiplier stage to make additional 100V or so but modulated by the blanking transistors and the intensity control setting the overall DC level.
