Hi there,
I recently bought an LG3236 off of ebay, and everything worked fine except for the output signal dropping as soon as I hit 101dBu, right when the relay kicks in. I had it open to clean all the controls, so I figured I would dive deeper into the RF output section. I opened up the shielded enclosure, and traced the signal back from the output. I noticed that when the signal hits 101dBu, it gets switched over from a bypass bus line to run thru some amplifier circuitry. I also found that the signal drops out after reaching U1, a small round 4-pin smd labelled "1." I measured this part and it has a very low resistance, but I cannot find any info about it.
Can anybody help me identify this part? I also suspected that the rf amplifier RF2317 is bad, but I'm not sure.
Any help is much appreciated
Thanks,
ratlord
