Author Topic: Leader scope lost its sweep  (Read 2880 times)
Offline sweatybettyTopic starter
« on: September 13, 2020, 08:19:51 pm »
Hello all!
New guy here looking for some help. I'm working on a Leader LS8106A scope that has lost the horizontal sweep.
I have replaced all the capacitors on the power supply board, all voltages check out OK.
I'm hoping someone can point out which part of the circuit controls the sweep. The schematic isn't marked as to which section is which.
I'm going to attempt to attach the FSM to this post, don't know if I'm allowed.
thanks all    sb
Re: Leader scope lost its sweep
« Reply #1 on: September 13, 2020, 08:22:58 pm »
Well either the file is too large or I'm too new here  to use the attachment feature.
Offline bdunham7
« Reply #2 on: September 13, 2020, 08:28:27 pm »
"Lost its sweep" is a bit general.
Is the screen blank or do you see a dot that can be moved around with the position buttons?
You could have a problem with triggering, the horizontal sweep generator or the horizontal amplifier, or perhaps something else.  Can you get the scope to work in XY mode?
« Reply #3 on: September 14, 2020, 12:10:56 am »
With the horizontal position knob centered, the trace (just a dot) is off the right side of the screen. Turn the knob full left and the trace is just right of center. In X-Y position, just the opposite.
My understanding is that there is a sawtooth pattern generated that drives the trace across the screen.
Also, please forgive me if I am using the wrong terminology.
thanks again   sb
Offline bdunham7
« Reply #4 on: September 14, 2020, 01:06:39 am »
I tried to talk another forum member through a similar repair and he is either waiting for some probes or has given up, I'm not sure which.  It may not be easy!  What other test equipment do you have and do you have a link to a schematic?
So, in general, the horizontal sweep generator will generate that sawtooth pattern, but it will only start when told to by the trigger circuit.  The sweep signal is fed into the horizontal amplifier which connects to the horizontal deflection plates in the CRT.  The problem could be anywhere in those systems, or in their power supplies.
In XY mode, there is no sweep and the dot is moved horizontally by the X input and vertically by the Y input.  Any input on the X channel should turn the dot into a horizontal line.  Try that first--you may have to adjust the input level to match the signal, but you should get a line, or for very low frequencies, a moving dot.  Do you have a good signal generator?
« Last Edit: September 14, 2020, 01:08:48 am by bdunham7 »
Offline floobydust
« Reply #5 on: September 14, 2020, 01:45:29 am »
Is the CRT readout text also off screen?  https://www.eevblog.com/forum/testgear/leader-ls8106-oscilloscope/
You could post the service manual to The Boat Anchor Manual Archive BAMA  ;)
« Reply #6 on: September 16, 2020, 01:03:50 am »
Hello.
bdunham7
As far as equipment I have another scope, several VM's and a signal generator. Ill try your advice about X-Y mode tomorrow afternoon.
floobydust
The readout text is on screen as it should be.
Im going to try attaching the horizontal board schematic just to see if I can post a small pic. If not, Ill try BAMA
thank you both
« Reply #7 on: September 16, 2020, 01:29:52 am »
More than 1 way to skin a cat. I also sent the entire file to BAMA.
« Last Edit: September 16, 2020, 01:34:29 am by sweatybetty »
« Reply #8 on: September 17, 2020, 12:12:14 am »
Short video. 5hz sine wave at 1.5V. I was moving the H-pos control back and forth.
Offline ambrosia heart
  • Country: hk
« Reply #9 on: September 22, 2020, 03:28:08 am »
Hello all!
thanks all    sb
The sweep circuit of your oscilloscope has 6 parts:
(1) schmitt circuit [not shown]
(2)sweep gate circuit
(3)free run circuit
(4)ramp generator circuit
(5)hold off circuit
(6)sweep stop circuit  and
(7)sweep selection circuit
How to measure:
see your upload 48-49 & 8106hb :popcorn:
make sure ALL concerned  circuits supplied with proper  voltage.
(0)Oscilloscope in auto mode with intensity at minimium, i.e. Spot not seen.
(1)measure waveform at X+ & X- output first.  If no waveform, measure preceding stage marked with a cross in green. :-BROKE
(2)If no waveform at ALL (1),  measure waveform marked in red 1,2 & 3 located in Q. :-BROKE
(3)Is waveform at Q pin 2 marked in red (4) in High, otherwise, no sweeping in auto mode. :-BROKE
(4)If (3) is high, check ALL components with with arrows :-BROKE
When an oscilloscope under test changes time base, so does sweeping waveform on screen.
  • Country: hk
« Reply #10 on: September 24, 2020, 05:28:38 am »
waveforms
  • Country: hk
« Reply #11 on: September 24, 2020, 05:31:18 am »
waveforms
« Reply #12 on: September 25, 2020, 07:21:27 pm »
ambrosia heart
Q110
Collector 1st pic 5mv/div
Base/emitter 2nd pic 5mv/div
« Reply #13 on: September 25, 2020, 07:24:11 pm »
Q112 Q307 and Q308
same pattern all 3 terminals
Same thing on pin 2 IC108
all at 5mv/div
« Last Edit: September 25, 2020, 07:29:15 pm by sweatybetty »
« Reply #14 on: September 25, 2020, 07:39:14 pm »
Pin 13 IC's 109 & 110
5mv/div
« Reply #15 on: September 25, 2020, 08:54:46 pm »
Found the waveform. Its coming off the -8V supply. Going to check the power supply board.
Waveform is gone.  -8V is now normal. Everything points to IC108, might order a new one.
« Last Edit: September 25, 2020, 10:09:04 pm by sweatybetty »
  • Country: hk
« Reply #16 on: September 26, 2020, 02:22:05 pm »
ambrosia heart
Q110
Actually, no sine wave will observe in this circuit.  Replacing faulty IC108 may get it fixed.  If not fixed, repair ramp
gen. circuit. The X plate amplified signal drives electron beam sweeping across screen.  See waveform with x10
probe.  IC108 pin 2 signal also shown in auto and fix mode, it gives a straigth line in norm & single mode. :popcorn:
« Reply #17 on: September 27, 2020, 04:51:30 pm »
Ordered a couple new IC's and sockets. Ill give an update when I get it installed.
Appreciate the help  :-+
The following users thanked this post: sprit
