Author Topic: Leaky batteries  (Read 2117 times)
Offline FungusTopic starter
Leaky batteries
« on: August 25, 2015, 04:54:39 pm »
What's the best way to clean up the springs in a battery compartment if a battery has leaked a bit and corroded them?
Re: Leaky batteries
« Reply #1 on: August 25, 2015, 06:37:03 pm »
NiCd or NimH cells use vinegar. Other alkaline cells as well, followed by a rinse with a paste of baking soda and a final few water washes while scrubbing with a nylon brush. Finally with bare metal use a light coat of grease, baseline or siliconer grease, to keep the bare metal from corroding further.
Offline Daniel_Reyes
Re: Leaky batteries
« Reply #2 on: August 25, 2015, 08:33:54 pm »
Pee on it.
Sent from my SM-G900P using Tapatalk
Re: Leaky batteries
« Reply #3 on: August 26, 2015, 09:15:15 am »
If you can dismantle it, hot water will dissolve most of the salts deposited as a result of the corrosion and for just the contacts, boiling water. Then as Sean describes Baking Soda is a good neautraliser.
Sometimes I will tin contacts with solder to help prevent further oxidisation, but if the contact tension is weak it pays to rework the contacts for trouble free operation.
Re: Leaky batteries
« Reply #4 on: August 26, 2015, 12:03:43 pm »
Will try the suggestions, thanks.
(Taking it apart first definitely seems to be the way to go.)
