But I am not familiar with smd solding, so need Help
greetings
Martin
It is not hard but you will need:
Practice before actual rework on old SMD PCB's.
Jewelers magnifying headset.
Fine stainless tweezers (non-magnetic)
Some type of fine and soft hot air heat source.
Liquid or paste flux.
Some fine tips, 2.4mm max. Hoof and chisel work fine. Do NOT use conical, they have insufficient thermal mass !
Helpful hints/advice:
Use only leaded solder so to not need too much heat.
Wet/dilute existing solder with fresh solder and then sucker/braid.
Hakko K style knife/skew tips will bridge both pads of most SMD passives so removal is easy; sweep off or pull with tweezers.
Really only IC's need hot air for removal.
Most rework won't need solder paste.
Be careful with SMD electrolytics, it's easy to lift a pad.
