Hello everybody,
I'm new to the forum, and I hope the post is in the right board.
I've got a problem with a LeCroy 104 Xi-A scope that I haven't used in a bit of time. When I power on the unit, the screen lights up but the LeCroy simbol doesn't appear and, in addition to this, the fan of the cooling system doesn't slow down as it used to do and the device remains in this state until I manually plug off the power.
After reading a bunch of posts on this forum I've take apart the scope and changed the 3V cr2032 battery which is on the motherboard, because the problems described seemed to me quite similar to the ones I have, but unfortunately the problems aren't gone.
Thank you in advance for your suggestions.
