Author Topic: LeCroy WaveSurfer 10  (Read 629 times)
Offline TeichhermelinTopic starter
« on: January 06, 2024, 09:45:34 am »
Can you find the error yourself? Or is this just a service at Lecroy?
The 4th channel no longer displays the calibration signal correctly. :o
Offline shakalnokturn
Re: LeCroy WaveSurfer 10
« Reply #1 on: January 07, 2024, 03:40:01 am »
There's apparently a small value of capacitive coupling letting the fast transitions appear.
Estimating the capacitance may give you a few hints for troubleshooting.
It could be a broken connection at the BNC, defective relay, or fault somewhere in the low frequency path in the front-end.
Even without schematic comparative probing  should get you to the problem easily, the main issue is how to run it disassembled while keeping things cool.
The following users thanked this post: 2N3055, Teichhermelin
Offline boB
    • my work www
« Reply #2 on: January 07, 2024, 04:28:06 am »
Have you tried swapping probes on channel 4 ?
K7IQ
« Reply #3 on: January 07, 2024, 08:53:08 am »
I did that. :-+
« Reply #4 on: January 07, 2024, 08:53:48 am »
When I have a lot of time I'll take a look at it! First of all, thank you for the information!
