Author Topic: Lecroy wavesurfer 3024 fail to boot  (Read 20998 times)
Offline gkmaiaTopic starter
  • Electronics Hobbyist
« on: December 01, 2021, 03:36:23 am »
My Wavesurfer got stuck on a blue screen while trying to boot.
I've uploaded a video on youtube showing the issue.
Also found the scope recovery notes, but seems it do not apply to my as the Wavesurfer does not have a recovery procedure.
Cheers
Gui
Offline kendor
Re: Lecroy wavesurfer 3024 fail to boot
« Reply #1 on: December 01, 2021, 07:58:27 am »
Exact same thing happened to me two weeks ago. I was desperate ;)
Turns out you have to re-flash your scope/run a recovery disk. This is done by the Micro-SD on the back of the file.
I've uploaded you the recovery disk here: https://tmp.yxc.ch/wl/?id=8qaTN2VHKrAbuceZwjrNxd629KcMKVvS
Extract all files on an SD and boot - it will do. After recovery make sure to remove the files again, or it will do a recovery over and over again.
After recovery make sure you update your bios, with the new bios it should not enter an infinite boot loop anymore. You can download the latest firmware here:
https://teledynelecroy.com/support/softwaredownload/documents.aspx?sc=12 ( I also uploaded the latest version for a WaveSurfer 3000 in above link)
Let me know if it worked
Cheers
« Last Edit: December 01, 2021, 08:05:39 am by kendor »
The following users thanked this post: 2N3055, analogRF, Belgarath, jkridner, heatsystem, ozel
« Reply #2 on: December 01, 2021, 07:57:03 pm »
WOW! Thanks Kendor!
Amazing, I will try it right now!
« Reply #3 on: December 01, 2021, 08:49:22 pm »
I tried and it worked!!! Great tip mate. I really appreciate!
« Reply #4 on: December 02, 2021, 06:12:05 am »
Oh so you nabbed it and you got quite a good scope now it's recovered.
https://www.eevblog.com/forum/testgear/teledyne-wavesurfer-3024-200mhz-oscilloscope-any-good/
Investigations at the time indicated only a LeCroy recovery package would fix it.
« Reply #5 on: December 02, 2021, 06:32:59 am »
Did you work with Martin Jet Packs?
I contacted Lecroy. They were quite friendly but did not want to go as far as providing files, etc... I was about to send it to them to fix. The re-flashing disk Kendor provided was the salvation.
Also it has the signal generator extra.
I will get the digital now and it will be a neat piece of equipment.
« Reply #6 on: December 02, 2021, 08:27:36 am »
No, only had interest in it as our customer Dazz1 that's not too far from you in the Hutt was interested in it and I recognized it as a Siglent rebrand.
Study the thread I linked.
Yes I could get the SDS3000 recovery files from Siglent but after it would have no longer been a LeCroy.
You certainly owe Kendor a beer or 2.  :)
By the looks of the MSO socket the probe is most probably all passives and likely you can find one on EvilBay for not too much.
« Reply #7 on: December 02, 2021, 01:16:42 pm »
I had a vision the MSO probe set was the same as earlier 2k Siglents but no it's a SPL3016.
Scroll down to see it here:
https://www.siglent.com/products-ware/sds3000x/#navs
Offline heatsystem
« Reply #8 on: December 02, 2021, 02:28:02 pm »
I've got the same problem with boot with WS 3024, MFG Date Sep-2015.
I tried the recovery disk from kendor but it still doesn't boot to UI.
Can someone help?
Thanks for help
heatsystem
« Reply #9 on: December 02, 2021, 03:20:05 pm »
Can someone help?
Thanks for help
heatsystem
Welcome to the forum.
Did you format the SD card and have all files in the root ?
« Reply #10 on: December 03, 2021, 01:16:47 am »
Can someone help?
Thanks for help
heatsystem
The card I used was the original card and it was formatted as a Master Boot Record. I think this will play a role. Try formatting the card as FAT - MBR. My card root directory looked like the image attached.
The following users thanked this post: heatsystem
« Reply #11 on: December 03, 2021, 01:20:06 am »
Do you know if I require a key to activate the WS3K-MSO function? Or just by sticking probs there it will enable it. I tried pressing the digital button at the front panel and it does not do anything.
WS3K-FG has been included.
« Last Edit: December 03, 2021, 01:28:16 am by gkmaia »
« Reply #12 on: December 03, 2021, 01:49:36 am »
Yes, see the description of the option, it includes the SW license.
Hunt out the Options menu and check what is licensed and if any other options have trial use times remaining.
Don't know if LeCroy offer trial uses but Siglent do 30.
Offline heatsystem
« Reply #13 on: December 03, 2021, 05:53:12 am »
Thats it: I formatted with diskpart on command-line (clean disk, create partition primary, active, format fs=fat quick), copied all the files, started the WaveSurfer and after some minutes it started as expected!
Thanks to kendor and gkmaia!  :-+ :-+ :-+
heatsystem
The following users thanked this post: gkmaia
« Reply #14 on: December 04, 2021, 12:15:55 am »
I checked. Has all the decoding options plus the function generator. But does not have the MSO. Still an amazing score for $800!
Offline peter-h
« Reply #15 on: December 20, 2021, 08:51:48 pm »
I had the same boot problem with a 3034 about 2 years ago; 1 year from new. They fixed it under the warranty, but next time it will be expensive; AFAIK their fixed repair charge is about 1k.
Offline ollopa
« Reply #16 on: January 10, 2022, 09:04:33 pm »
The WS3K (non-Z) uses the TI DM3730 OMAP3 SoC, for which there is no such thing as a "BIOS".  By watching the serial console output during boot I can see that what this "BIOS" update actually does is upgrade the NAND flash ECC algorithm.  I think they were using the default Hamming correction which can only correct for 1 bit error.  The DM3730 is capable of hardware computed BCH-4 and BCH-8 however the silicon errata says that BCH-4 is completely broken.  I think we can assume they are upgrading to BCH-8.  The MT29F4G16ABBDA3W NAND flash used also has OOB size 64 which is large enough for BCH-8.
The nature of NAND flash is to have a high probability of bit errors and it requires error correction.  I think we can assume that the initial ECC algorithm used was too weak and eventually all scopes will need this recovery process and the "BIOS upgrade" which actually just re-computes NAND flash ECC data.
First boot after confirming the "BIOS  :-DD upgrade" (The screen shows four colored squares and updates the block number during each ScreenPrint call logged)
Lecroy NAND XLDR, Jun 26 2020 at 23:39:17 Version BSP_WINCE_ARM_A8 2.30.00.03...............JMP
Lecroy EBOOT 0.0, BSP BSP_WINCE_ARM_A8 2.30.00.03
TPS659XX Version 0x10 (ES1.1)
>>>>> EBoot Boot Perf timer 1
Preparing for download...
ECC 0
Checking bootloader blocks are marked as reserved (Num = 32). Min:29
IsFlashBlockConfiguredForInternalEccCorrection 4, ff,ff, rc:0
ECC 0
INFO: Boot CFG ... OK
>>>>>Boot configuration Duration 21ms
ECC 0
ECC 0
IsValidMBR: MBR sector = 0x800 (valid MBR)
OpenPartition: Partition Exists=0x1 for part 0x20.
ECC 0
>>>>>LCD.BIN extracted from NAND Duration 71ms
 >>>>>>>spi load fpga start time=93
 >>>>>>>-SPI_WriteRead(rc = 465028)
 >>>>>>>spi load fpga end time=372
>>>>>LCD.BIN written to FPGA Duration 279ms
ECC 0
>>>>>Logo displayed Duration 356ms
>>>>>Partitions checked Duration 0ms
>>> Forcing cold boot (non-persistent registry and other data will be wiped) <<<
>>>>>Reset checked Duration 9ms
Init HW: controller RST
SDCardInit: No media!
BLSDCardFileExists:  fileio init failed
SDCard: menu.bin not found
SDCard: format.bin not found
SDCard: recovery.bin not found
>>>>>BLShowInitLogo displayed Duration 621ms
ScreenPrint
Reconfiguring flash for 0 to 3 ECC correction
ECC 0
 ReconfigureFlashIntToExtECC - Updating block:4
ScreenPrint
ECC 0
ECC 3
FMD_EraseBlock  4
 ReconfigureFlashIntToExtECC - Updating block:5
ScreenPrint
ECC 0
ECC 3
FMD_EraseBlock  4094
 ReconfigureFlashIntToExtECC - Updating block:4095
ScreenPrint
ECC 0
ECC 3
FMD_EraseBlock  4095
ECC 3
ECC 3
FMD_EraseBlock  5
ScreenPrint
ECC 3
FMD_EraseBlock  5
>>>>>Special files checked Duration 175580ms
>>>>>Logo displayed Duration 0ms
ECC 3
BP_SetDataPointer at 0x0
>>>>>OS Image loaded Duration 21960ms
Launch Windows CE image by jumping to 0x81002000...
And then on the next boot post-upgrade:
ECC 0
IsFlashBlockConfiguredForInternalEccCorrection 4, 3,fc, rc:1
ECC 3
ECC 3
>>>>>Boot configuration Duration 22ms
ECC 3
ECC 3
ECC 3
>>>>>LCD.BIN extracted from NAND Duration 82ms
 >>>>>>>spi load fpga start time=105
 >>>>>>>spi load fpga end time=383
ECC 3
>>>>>Logo displayed Duration 377ms
>>>>>Special files checked Duration 371ms
>>>>>Logo displayed Duration 4ms
ECC 3
>>>>>OS Image loaded Duration 21969ms
Windows CE Kernel for ARM (Thumb Enabled)
OAL: CPU revision 0x12:DM3730
OAL: CPU L2 Aux register 0x400042
****Profiler Build****
---High Performance Frequency is 26000847 hz---
The following users thanked this post: ozel
Offline eevChrissy
« Reply #17 on: February 03, 2022, 07:57:55 pm »
Hello,
I have similar issue with a WS3024.
After doing recovery, it hangs now in the screen with the 4 colours in each quadrant.
May, I am missing something!?
How can I watch that nice "serial console output during boot"?
And, as a last option, is it possible to recover to a SIGLENT SDS3000? Guess the calibration would be lost...?
Very Best Thanks, for any help!
Offline ollopa
« Reply #18 on: February 06, 2022, 05:38:49 pm »
It is supposed to update the flash block number on the screen as it rewrites the ECC data.  The operation can take a while.
If you don't see the screen updating and you have patiently waited several minutes then there is probably an error it can not automatically fix.
My WS3K still had trouble writing to flash after the recovery.  I had to boot under Linux and erase the NAND flash, then perform the recovery.  Afterwards it has been operating fine.  I don't know if you will lose cal data because mine had calibration issues to begin with.  It was, and in some ways still is, a very sick scope.
If you want serial output you have to disassemble the scope until you have access to the main board, then solder a header or some wires to three pads and connect a 3.3V FTDI or equivalent.  I don't have a picture right now and my scope is partially reassembled so I cannot just go snap one.  If you want to go that far, however, I can pull the shielding back off and take pictures sometime in the next few days.
Offline eevChrissy
« Reply #19 on: February 07, 2022, 05:50:17 pm »
@ollopa
Very Best Thanks for that help...
Think, I can open it, and create a serial COM connection over FTDI...
But, right now, I didn't understand the second step...
How to Boot Linux and erase the NAND flash ???
Thanks for further help... and Best regards
Offline scopeman
« Reply #20 on: February 07, 2022, 06:54:40 pm »
Hello,
Also you might want to join and post to my LeCroy group on groups.io
Thanks and great to see that your scope is up and running!
https://groups.io/g/LeCroyOwnersGroup
Sam
W3OHM
LeCroy Group Moderator on groups.io
W3OHM
Offline zhongzuocheng520
  • Country: cn
« Reply #21 on: August 15, 2022, 11:20:35 am »
According to the recovery method you provided, the recovery can only be performed until the 4-color screen has been waiting and cannot be entered.
Offline kinero
« Reply #22 on: April 30, 2023, 05:59:23 pm »
Kendor, do you know if you the restore procedure would work on a unit where the BIOS update already took place?
Offline kinero
« Reply #23 on: May 01, 2023, 03:04:24 am »
This recovery worked well for my scope, but....after the unit was recovered, the supplied 9.6 firmware was installed, and the BIOS was updated, I noticed two things:
(1) "ADD KEY" button for options does nothing, so I'm not able to add options that I purchased.
(2) can no longer browse system files; only contents of USB DRIVE or SD card are displayed.
I want to perform a factory restore again to see if these problems go away, but I don't know if the updated BIOS would also be rolled back. If not, the system will attempt to run factory firmware on new BIOS which I don't believe will work.
Does anyone know?
Offline ollopa
« Reply #24 on: May 01, 2023, 03:36:41 am »
I had the same problem with the licenses no longer being installable with version 9.x firmware.  This seems like a bug in their software.  I rolled back to earlier firmware and it was OK.
This is an ARM SoC, not x86 architecture.  There is no such thing as a BIOS.  As I explained already, that step is actually changing the error correction algorithm for the NAND flash.  The recovery software completely reformats flash so it is no problem to use it to go backwards after doing the upgrade.
