Author Topic: Lecroy wavesurfer 3024 fail to boot  (Read 34945 times)
Offline chenobalun
  • Country: cn
Re: Lecroy wavesurfer 3024 fail to boot
« Reply #75 on: April 06, 2026, 09:48:04 am »
@tautech Sorry for asking about "how many beers you would like to have"; I understand that you have never expected many beers from people who need help on this forum.
Update: Jiayu Wu at Siglent HQ has sent the SD recovery package and the firmware update file for SDS3000 series to me, and I restored the SDS3104 oscilloscope's firmware successfully.
I was about to install the TI Code Composer Studio when I realized there are some write-only registers in peripherals like GPMC (this means I shouldn't try to dump the whole register address range of the peripheral with OpenOCD), right before receiving the recovery package. I decided not to continue the effort with the JTAG; however, checking the front and back sides of the mainboard (SDY8.007.045E, ACQ2_131100), the EEPROM wasn't found; It seems like the BTD data can be backed up within the "Lecroy" folder, but the "Restore BTD from EEPROM" in the service menu failed with error. I wish the model data is stored in some MCU or something in the front panel, not in the NAND... Anyway, "Restore BTD from EEPROM" isn't really needed at least at this moment.
Side note: I've seen the "Programming the mainboard microcontroller" message while doing the FLA firmware update.
« Last Edit: April 07, 2026, 07:08:13 pm by chenobalun »
Offline lincoln
« Reply #76 on: July 22, 2026, 03:18:24 pm »
Exact same thing happened to me two weeks ago. I was desperate ;)
Turns out you have to re-flash your scope/run a recovery disk. This is done by the Micro-SD on the back of the file.
I've uploaded you the recovery disk here: https://tmp.yxc.ch/wl/?id=8qaTN2VHKrAbuceZwjrNxd629KcMKVvS
Extract all files on an SD and boot - it will do. After recovery make sure to remove the files again, or it will do a recovery over and over again.
After recovery make sure you update your bios, with the new bios it should not enter an infinite boot loop anymore. You can download the latest firmware here:
https://teledynelecroy.com/support/softwaredownload/documents.aspx?sc=12 ( I also uploaded the latest version for a WaveSurfer 3000 in above link)
Let me know if it worked
Cheers
Thanks to this legend I was able to recover and update my WS3034.
On his web archive, he has maui 9.6.0.1. Lecroy's web site the latest published is 9.2.0.5. Not sure what is up with that.
Link
Offline yybird
  • Country: cn
« Reply #77 on: September 06, 2026, 07:19:22 am »
Hi chenobalun,
I read your post that you received both the SD recovery package and firmware update file for the SDS3000 series from Siglent.
I also have an SDS3000 suffering from boot‑up problems.
If you cannot post these files publicly on the thread, could you send them to me via PM?
I promise I will not redistribute or share them with anyone else.
Thank you so much for your help.
