What test equipment do you have?
More information would be useful in making a diagnosis. But, taking a flying guess, I would guess that something is shutting-down due to thermal problems. Could be the display driver but more likely a voltage regulator. If it is the later it could be due to faulty caps across the supply (look for something(s) getting hot), or it could be due to reservoir caps drying out, or it could just be a faulty regulator.
