Some of them have a zebra strip between the pcb and the lcd glass, sometimes a cleanup can solve the problem, or maybe there is not enough pressure to make a good contact ?
You can use you fingers to pinch the lcd frame and the pcb to see if it goes away ?
An zoomed out photo to see the whole lcd assembly would help
