Hi everyone,
Couple of weeks ago I bought (it was so cheap I would rather say found) a TR6845.
It was working for a few days, far out of calibration though. I was unable to find any documentations on the web so started to play around with.
What I figured out is there is a hole at the bottom of the case with a switch under it. When you turn the switch on, the display start blinking.
Now you connect the unit to a, let's say 10.008k
resistor you can calibrate it pushing the "shift" (green) button on the front panel. The display change to 00000 or 10000 aso depend on the range (I tried with auto range make it simpler) the first digit is still the rest is blinking. Now you can adjust the first digit with "up" and "down" buttons on the front panel, when it's done you can jump to the next digit with the "auto" button aso. After all are set hit the shift again and that's it. The procedure is the same with the voltage just change the function to VDC and the source to voltage, obviously. I assume this all true for the rest of the functions but I didn't have a chance to try.
I had ERR 2 messages twice since I have the unit but after a restart it was working again.
Two days ago when I turned it on I had an "ERR 4" message and dead silence.
I found nothing on the web so teared it down. only thing I found was two cable connection was broken to the front panel board. See: Connect.jpg
Likely they broke during the tear down (IMHO it's a bed design and you can find the same solution on the other 2 boards too)
And now I don't know where to go.
I would appreciate for every suggestion except for the "Buy a new Fluke for $2000" and alike.
BTW what is this component? See: something.jpg
It looks like some kinda capacitor, vacuum between two plates but I don't have clue. on the board there is a printed "VL201" under it.
