There is 55 Leds on the board with two channels. One channel has a voltage of 92 volts and the second channel is 90 volts. I assume one channel drives 28 Leds and the second 27 Leds. Would not the zener also have to have a 3 watt rating the same as the LED?. No way these tiny SMD diodes have a 3 watt rating.
Well, if it is a single string - 92V / 55 Leds = ~1.7V per Led. That doesn't look right for a high powered Led, I'd say max 50mA = app 90mW, which should be fine.
IF there are 2 strings (1/2 ea), which is common, then that's ~3.4V per Led, which is more likely a higher powered type. Then yes, it needs the same power rating.
On the channel that blew one LED was shorted along with the diode and a number of other LEDS were dark and look like they overheated or were overdriven.
Now we have a quandary :-) What I didn't mention is - IF a Led (or diode)
does go short cct, AND it is NOT a Constant current type drive (ie fixed voltage), then the string current will go up by ~ 1/55x for first instance, 1/54x the second etc, rising faster each time. BUT, for only 1 shorted, I can't see the current increase being enough to cause what you see !!?
Something is fishy here :-)
