Author Topic: Lenovo B570 laptop optical drive problems  (Read 1565 times)
Online Alex EisenhutTopic starter
  • Place text here.
« on: July 16, 2016, 06:27:32 pm »
Symptom: Barely ever recognizes disc. Many different discs that play fine in my stand-alone player. Cleaned the discs, cleaned the lens. Same result.
OS: Win 7
Drive: TSSTCorp CDDVDW TS-L633F
Firmware: LE02
Player software: VLC
Tried all the standard "troubleshooting", nothing. There's no malware on the PC, no driver issues. I tried to find new firmware for the drive but by the code it's a Lenovo special, nothing I could find.
Is it possible to know what the stupid drive is doing so I know where it fails? Can I find out the optical power the block is putting out with software?
I installed Opti Drive Control, but it gives high level info. It just says "insert disc"!  :-DD when I ask for a test, it seems to want to test the disc, I want to test the drive!
So eventually after rebooting the PC and inserting the disc a few dozen times it eventually sees the disc and plays fine. Even when it plays "fine" it trips up on slightly scratched discs.
The thing is ancient (2011) so all I could find were pulled spare drives.
Yes I still use DVDs, I get to watch tons of stuff from the library!  O0 Uh, when it works, that is...
Offline Monkeh
Re: Lenovo B570 laptop optical drive problems
« Reply #1 on: July 16, 2016, 06:35:49 pm »
Just buy a drive. Like.. any drive. They're pretty standard, just pop the faceplate on. Just don't buy any thing from TSST, they're universally junk.
  • Place text here.
« Reply #2 on: July 16, 2016, 06:38:01 pm »
in a laptop? They're all the same? OK, I'll look around. And yes, I can see that TSST is pretty junky...
Offline Monkeh
« Reply #3 on: July 16, 2016, 06:54:08 pm »
I believe that's a SATA drive, so yes, they're standard. I doubt Lenovo used a special connector (I think I have a B570.. I'll have a look).
The only trouble may be with the faceplate, but usually they're fairly compatible.
