Good morning,
I have a Lenovo Ideapad 320 4GB Ram --> 8GB Ram(W10) laptop with a 1TB 2.5 inch hard drive and since 2018.
He’s starting to drive me crazy, because his condition seems to get worse and worse with response times getting slower and slower.
Initially I was told you don’t have enough memory, so I upgraded to 8GB Ram. It seemed a little better, but no more.
Now it’s just infernal, with latencies of 2 to 3 seconds. I was told look at the virtual memory, but it hasn’t changed anything.
I tried to reinstall everything, to remove everything that can gener at startup, etc, it’s the same.
So I analyzed the disc and ordered a 4 TB SSD at A...x.
The analysis was done with Crystal Disk info and GSmart control.
crystal disk info says everything is fine (Weird I have values above the threshold if I’m not mistaken), and Gsmart tells me the opposite, but be careful it seems that reading Seagate info can be wrong.
I point out that the disc "Swappe" constantly and the fan does not stop blowing. In addition, in the task manager we find ourselves either at 100% CPU, or at 100% disk.
So I started reinstall windows on the SSd disk (I’m waiting to get a caddy to clone), and there again no luck the laptop freezes after 2h00. The SSd is really hot.
I put you the photos of the disc to get your opinions on its design, there is so much fake, but it seems to me "true", not made with SD cards.
I was still able to make a copy of a folder of 23,000 files from C to D (from the SSD disk), we start at 150 MB/s to an average of 50 MB/s.
The cpu at the time of copy is also 98%!!!
So my questions, is the disc dead?
Is the SSD a real one?
Are its capabilities more limited by the design of the laptop? Outdated cpu, etc
All your opinions are welcome.
only PB, I have no other hard CD or SSD to test.
