Author Topic: lenovo laptop  (Read 719 times)
Offline dazqTopic starter
lenovo laptop
« on: June 01, 2020, 06:58:27 pm »
hi guy so looking for ideas on how to do this the wifes lenovo laptop keyboard has gone faulty 1 key just the w after much testing have come to the conclusion its the membrane keyboard need replacing so i looked in to this and you can buy just the keyboard but the frame is sonic riveted to the top plastics and the keyboard is sandwiched in the middle here is a link to some images of the top plastics on ebay https://www.ebay.co.uk/itm/Lenovo-Ideapad-330-14-AST-PalmRest-Top-Case-Keyboard-UK-Casing-Cover-AP185000350/233126195575?_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20160811114145%26meid%3Df5343a3d34b948f8b920d8c25e1f4d4e%26pid%3D100667%26rk%3D2%26rkt%3D8%26mehot%3Dnone%26sd%3D282544532576%26itm%3D233126195575%26pmt%3D0%26noa%3D1%26pg%3D2334524%26brand%3DLenovo&_trksid=p2334524.c100667.m2042 if i brake the rivets is there a way to reform then connections maybe like some epoxy through the holes and left to set or do you think the small amount of screws will be sufficient to hold it together? there is like 24 rivets   thanks
« Last Edit: June 01, 2020, 07:00:01 pm by dazq »
Offline vidarr
  • Country: br
Re: lenovo laptop
« Reply #1 on: June 01, 2020, 08:07:59 pm »
Are you replacing the entire piece as shown in those pics? Or, are you just replacing the keypad?
If you are replacing the entire piece, take a pic of the laptop with that piece removed.
If you are just replacing the keypad, you will have to use epoxy/glue.
« Last Edit: June 01, 2020, 08:11:53 pm by vidarr »
Re: lenovo laptop
« Reply #2 on: June 01, 2020, 08:27:31 pm »
hi it just the keyboard if i can get away with it but like i said its using that god awful plastic rivet system instead of like 30 pence of screws so to get the keyboard out i have to brake 24 of them then the plastic and metal will separate but i need to reattach after so epoxy in the holes is all i have thought of at the moment
Offline flolic
  • Country: hr
    • http://filiplolic.com/
Re: lenovo laptop
« Reply #3 on: June 01, 2020, 10:04:21 pm »
Remove the old keyboard by heating the "rivets" with hot air set at approx 200C. Use small nozzle and start from one corner. Pull the keyboard and heat the rivet, it will let go when hot enough. Go slowly rivet by rivet until keyboard and eventual reinforcement sheet is removed.
After that you need to clean melted remains of what is left of rivets, so that you can install new keyboard over them. I just use small bent tweezers and pull the remains.
Install the new keyboard and reinforcement metal sheet if there is one and double check that everything is on its place. New keyboard must lay perfectly and you must check every rivet (hole)! There is no going back if you find the error during next step!
Old cleaned rivets are barely long enough to be used again, but so far I never had a problem with them. You need to melt them again with the soldering iron. Set temperature at 230C or so and use conical or flat tip depending of rivets size and geometry. I usually use flat tip. Just squeeze the keyboard right next to the rivet and swipe the soldering iron tip over the rivet. It usually takes me half of second per rivet. Don't hold it longer and don't overheat, you'll just make a mess.
I have replaced maybe 10 keyboard using this method with 100% success.
Re: lenovo laptop
« Reply #4 on: June 02, 2020, 09:01:21 am »
thanks good plan will give it a go
