Hi folks,
I have a couple of Lenovo Pro2840mD monitors that I pulled out of an e-waste pile.
Both monitors work initially, but after a while, power down hard (no standby light, buttons unresponsive), and will not come back up unless power is cycled at the wall. Once power cycled, they last less time than when brought up cold.
I've hunted around but can't find replacement PSU boards for them.
I've buzzed out all the electro caps in the PSU, and they all appear to be good (capacitance in spec, no leaking, low ESR).
There are 2 control chips on the back of the PCB:
LD7790GS (
https://datasheet4u.com/datasheet-pdf/Leadtrend/LD7790/pdf.php?id=770292 )
GB98AEGN - backlight inverter? (
https://www.datasheetq.com/datasheet-download/142142/1/O2Micro/GB98A )
I'm guessing it's a temperature related issue based on the behaviour, but I need assistance in narrowing it down.
It would be tricky to bring the monitor up with the board exposed, due to how it's mounted (screwed into a metal shield which is then bolted to the back of the panel), otherwise I think using a thermal imager might reveal some candidates.
Does anyone have advice on how to investigate the problem further?
[EDIT] I forgot to mention, both these monitors are circa 2015
