Thanks, everyone:
wrapper: OK. Don't really want to be putting unnecessary heat into this board if I don't have to.
gamalot : Thanks, that's a big help. So, that confirms that they are bypass capacitors. The datasheet recommends a 10μF ceramic capacitor - This has two in parallel. I thought they were different sizes, but I just double checked, and they are the same footprint, and look to be the same thickness. I don't recognize device sizes at a glance, but with solder it measures 2mm × 1mm pretty exactly. About 0.8mm thick, by my horribly cheap plastic vernier!
Would a pair of 10μF capacitors make sense? Now I know they are bypass caps on the input side, I am confident that the value isn't critical.
amyk: Hmm.That schematic lists an array of a parallel 2.2n, 0.1U and 10U capacitors.
