I have the above mentioned phone and in it's charge port pcb, the port is missing.
You can see it in the attached images, the first 4 ones.
(the fifth image shows how it should be, I found it on the intenet)
I 'm trying to fix it although it's a cheap part, because it will take 2 months (at least) to come from China.
So, is there some service manual?
I found the
schematic, but...it only contains the...schematic (
) NOT the pcb.
So I can't find which part in the schematic corresponds to which part on the pcb.
Maybe the 'Switching Charge' of the schematic is the circuit of charge port pcb?
The phone is "dead".
I guess this PCB is the reason why it shows no signs of life.
The battery is new.
Any help is appreciated.
