Author Topic: lenovo smps repair , trouble identify the resistors  (Read 1226 times)
Offline BeetleJuiceTopic starter
  • Country: gr
« on: November 25, 2019, 12:45:14 pm »
hi there ,
i try to repair that smps , these two resistors (R10/R15) show 0.2ohms when desoldered from pbc.
i try to decode the colors but i am confused ! that silver in the middle doesnt make sense at all..
the smps had a mosfet burned , you see the x in the HS (IRF740).the other mosfet far left is K3934 and in the middle is a B129N diode.
thank you for the help in advance!
  • Country: gr
Re: lenovo smps repair , trouble identify the resistors
« Reply #1 on: November 25, 2019, 01:29:54 pm »
I believe its:
brown black gray gold green = 10.8 ohm 0.5%
black purple gray gold green = 7.8 ohm 0,5%
can someone verify this? it looks more like silver band but probably its gray.
Offline PKTKS
  • Country: br
« Reply #2 on: November 25, 2019, 02:26:38 pm »
I believe its:
The first one should be OK - in doubt I would measure it
The second one makes no sense.
Paul
Online wraper
  • Country: lv
« Reply #3 on: November 25, 2019, 02:36:17 pm »
0.1 OHm and 70 mOhm. These are not 5 band resistors. Green band should indicate resistor type, nothing to do with resistance. FYI resistors don't fail short.
Offline PKTKS
  • Country: br
« Reply #4 on: November 25, 2019, 02:45:44 pm »
Hmmm  they look like old style classic wire wound type
in something like a "new"  2Watt rating..
Do you have some table for these color codes?
Paul
The following users thanked this post: BeetleJuice
Online wraper
  • Country: lv
« Reply #5 on: November 25, 2019, 03:12:44 pm »
Paul
Most likely it's not power rating or any parameter. Say you can find in datasheet that this particular resistor series have green band. Consider this band non standard.
« Last Edit: November 25, 2019, 03:14:42 pm by wraper »
Online wraper
  • Country: lv
« Reply #6 on: November 25, 2019, 03:25:48 pm »
Here is example http://www.farnell.com/datasheets/87422.pdf.
MARKING
The nominal resistance and tolerance are marked on the resistor using four colored bands in accordance
with IEC publication 60062 “color code for fixed resistors”. There is a fifth white band in order to indicate the
type of resistor.
Standard values of nominal resistance are taken from the E24 series for resistors with a
tolerance of ±5%. The values of the E24 series are in accordance with IEC publication 60063.
  • Country: gr
« Reply #7 on: November 25, 2019, 11:16:27 pm »
Paul
omg how is this possible! since I don't have a milliohm meter I guess the 0,2 ohms i read with my multimeter shows that these resistors are ok.
they drive the two mosfets I think, I am not sure I should make a schematic to see the wiring.
i cant understand why these are not 5 band resistors, i mean what tells us that these are not? maybe the silver band that makes no sense?
you must be right, cause its impossible to have 2 resistors short to 0,2ohms the same time, so the most logical explanation is that they are sub-ohm resistors so my multimeter and the resistor table i am looking is wrong.
thank you for the reply!
« Last Edit: November 25, 2019, 11:19:54 pm by BeetleJuice »
  • Country: gr
« Reply #8 on: November 25, 2019, 11:21:15 pm »
any idea what these resistors are doing with so small value?
Online wraper
  • Country: lv
« Reply #9 on: November 25, 2019, 11:28:10 pm »
Likely current sense at MOSFET source.
